Although I've both original uniden Madison speaker's I only use one. It's not only a lack of space but both speaker's sound different. One gives a decent mix of high and low tone while the other is very bassy. I use the one with the better high and low tone mix. I'm assuming speaker technology has changed since these Madison speaker's were offered with the rig about 30 years ago. I'd like a single speaker with a 3.5mm (1/8") plug but I do have several 1/4" to 1/8" (3.5 mm) adapters. If the speaker is going to make the difference I'm expecting it too I don't mind what plug it comes with as long as I can purchase an adapter. I'd also like to be able to mount it to the utility cart that houses my setup. If the one suggested has a mounting bracket all the better. I am open to an amplified speaker if that's going to make a difference for the better. I've never used an amplified speaker but would rather not worry about powering it up unless it can be plugged into a 110 outlet. I don't know what the actual size of the speaker that's encased in the president labeled speaker housing but the case/housing appears to be 4" by 4" Square. It's much longer in length which to me is actually a waste of space. I have read that stuffing insulation or even an old shirt inside the housing usually gives the speaker a better sound. I doubt sound can come close to a new external speaker made specifically for ham, CB Radio or SW listening. There are so many available on eBay the choice seems daunting. Can someone suggest one that they use or have heard and will help the incoming sound on this radio. I have to believe there's a better soeaker then what was originally offered with the Madison (fourth generation) which I currently use. If you can share a link or two I would appreciate it greatly. It doesn't have to be an eBay seller. HRO, Cheap Ham or any seller of this type of speaker is fine.. Anywhere between $20 and $50 would be nice. If sharing Link's isn't an option suggesting frequency response of speakers that should make this Antiquated speaker I'm using
not only make my received sound better but actually blow it out of the water' would be excellent. thank you my friends. 73
