Swapping Out Radios
TexasOutlaw
199
2
Highlands, Texas
Its time for a change again. Since I find myself on L38 more and more I'm going to take the Northstar 88 out andf put the AR 3500 back in. Although I'll have to pull the driver amp out of line and just use the AR as a driver for my box. I'm also going to tune down the AR some as well. Hope to have all this done in the morning. Finally got my Nugatron mounted on top of my Ram Charger. Great ground plane lots of flat roof space.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
