I went off-roading, and my buddy could only hear my radio within 50 feet of the jeep. I figured something was wrong so I double checked my antenna K4 stud and mount. It's properly grounded on the bottom, the stud is not. I have a 4' firestick antenna. My SWR is pegged on all channels using an external radio shack meter. Something strange is that if I check continuity on the coax on the antenna side from the pin to the outside, I get a beep. This is when the coax is plugged into the CB on one end, and I'm checking continuity at the antenna side. Is that normal or is my radio fried? If I unplug the coax at both ends- I don't have continuity, so I know the wire isn't shorted internally.
HELP!
HELP!
