I got one of these:
and one of these:
Threw in a BNC to SMA adapter for my probes and I have a decent little 8 digit freq. counter that can be calibrated for less than $25. It would also show you where your 979 is TX'ing.
Blue RF Signal Frequency Counter Cymometer Tester 0.1-60MHz 20MHz ~ 2400MHZ+case | eBay
Independent double-IF design, adjust the minimum frequency step of 100 Hz, frequency range 0 ~ 99.9999 MHz, can be set to increase or decrease the IF frequency mode. The settings are automatically saved, boot directly call.
www.ebay.com
IPX IPEX UFL plug to SMA female 2hole Panel M3 Screw RG178 Coax Cable Kable FPV | eBay
12~ IPX IPEX UFL. 4 Way uFL plug to u.FL Socket SMD Black PCB RF113 cable IPX IPEX male female RF. MHF4 MHF 4 plug right angle RA to U.FL UFL on PCB Pigtail Coaxial Coax cable IPX. MHF4 to MHF4 plug right angle Pigtail Coaxial cable Kable WFL IPX4 RF 50ohm IPEX.
www.ebay.com
