Texas Star 350 concerns.. SWR jumping
Well I am moving in about 45 days and the amount of time I get to use the setup is minimal. All reports are good thus far.
I know the SWR is set at 1:1 on channel 18+ and 1.2-1.3:1 down on 1 and below abit.. I talk on 38, 415 where I'm know x10 to be flat SWR as I set the A99 for the higher channels..
I temporarily pulled the meter out of the line yesterday in case it was bad I didn't want an issue backing up into the amp etc.. if that's even a possibility.
Should I put the meter back at the end of the line and just keep a weary eye on it? Run the TS350 with the Variable?
I think your fine either wide open or green button in. From now on check your SWR on AM. Problem solved.
    Greg T has left the room.
