Texas Star Amplifier problems
Long night,
not a problem, i completely understand how something can read more complicated than it actually is.
so, the old diode was just a button with no leads on it.
the bottom of that old diode was soldered to the board.
that is ground.
so, the NON-banded end of your new diode (anode) gets soldered to that same spot.
the top of your old diode had a wire soldered to it. that wire had one end soldered to the fuses, and the other end soldered to that trace that is directly behind the spot where the old diode was. this wire was bent down so that the middle of it could be soldered to the top of the old diode.
looks like this:
so now you have your new diode with the NON-banded end soldered to that ground trace (where the diagram above says "D3").
the next step is to bend the other lead (banded end) over towards the back of the amp and solder it to that trace in the diagram that is directly to the right of the ground trace.
at this point you will have a diode with one end soldered to the ground trace (where the D3 label is in the diagram above), and the other end soldered to that trace that is just to the right of it (in the diagram above).
the last step is to get a short length of wire (12ga. or bigger, don't use thin wire) and solder one end to the top lead of your new diode (the end that goes to that trace on the right). the other end of this wire gets soldered to the fuse holder.
i know that we don't yet know which end of your new diode is the "banded end (cathode) and which end is the NON-banded end (anode).
the way we will figure this out is with our digital multimeter set to diode test function (probably has a diode symbol on that switch position).
take your positive (red) lead and touch it to one end of the new diode.
take your negative (black) lead and touch it to the other end of the new diode.
now look at the display on the meter. if it reads a voltage like somewhere around .6 volts (.583 for example) then your black lead is connected to the cathode (banded end) of the diode. put a mark or a line on this end of the diode.
if your meter doesn't read anything, then switch the leads around and re-read the paragraph above.
hope this helps.
Hi loose cannon. Your explination and instructions are very clear and most helpful to me with my limited knowledge. Don't know how to thank you for your help! I will be sure to let you know how this comes out when I get the new replacement diode.
Chuck Saylor
not a problem im happy to help.
please do come back to the thread with your results as it helps future forum members find answers.
we tend to have a lot of threads where people never let us know if the item ever got fixed or not.
good luck!
Long night,
that is ground.
looks like this:
hope this helps.
Hi loose cannon. You are very helpful and patient with me. I will follow your instructions and let you know how I come out. I will also get a new keying transistor just in case.
Thank you for all your help here
Chuck Saylor
Reactions: loosecannon
Long night,
that is ground.
looks like this:
hope this helps.
Hi loose cannon. I have my new reverse polarity diode and am ready to put it in. It is a button type with no marking to tell me which end is anode and which is cathode and looks the same on both ends. Can you tell me how to find which end is which?
Thanks Chuck
Reactions: NZ8N
Long night,
that is ground.
looks like this:
hope this helps.
Hi loose cannon. I was able to get the texas star 500 dx up and running. The only part that I needed to replace was the reverse polarity diode. Wanted to thank you for all your help and patience Sir.
awesome!!!
glad to hear that's all it was.
be sure to use two 35 amp fuses in those fuse holders.
if they blow because the amp draws more current than that on modulation peaks then you can go up to 40 amp fuses.
awesome!!!
Personally I would ditch those fuse holders and upgrade to 8ga wire to each board for both positive and negative combining into an anderson connector, and put the fuse as close to the supply as possible.
I don't have factory fuse holders in any of my TS amps anymore.
I ditched the ones from my 667 25 years ago and my Sweet Sixteen never came with them.
They are just too prone to failure and upgrading the power wire both keeps the power wire cooler and helps the amp do what it's capable of doing. I gained 150 watts on my 667 when I upped the power wire. It's a very worth while upgrade.
Like this.
Like this.
Thank for the great information on this. Will do!!!
Like this.
Agree the stock fuse holders are failure prone , I have seen them get hot and fail on both the 500 and 667.
I do the power wire upgrades as well.
just make sure you have the right soldering tools for soldering to large gauge wire, and the fabrication skills to enlarge the holes so you can put proper strain relief on the new wires.
also don't forget to put a fuse in line near the amp, and as with any wiring that goes straight to the battery, a fuse right at the battery for fire protection.
sure thing, but let's do a couple of tests to make sure you have found your problem.
first a question, did you test the diode that was removed and confirm that it was indeed shorted?
you have to remove at least one side of the diode from the circuit in order to test it.
next, if you did test and remove the old diode, you should set your multimeter to read continuity and confirm that there is no connection from the positive side (you can measure this at the fuse holders) to ground. (the big wide trace the bottom of the old diode was soldered to)
we want to make sure that the diode was the culprit and not a symptom of another problem.
so check these items before installing your new diode.
when installing your new diode, you want the cathode (banded end) connected to the positive side, and the anode connected to ground.
this way, the diode won't conduct when power is connected properly.
if the power is connected backwards, the diode will conduct and blow the fuses.
this is one reason not to just put way over sized fuses in there, as they won't blow before more damage is done to the amp.
so, to determine which end of the diode is the cathode (banded) and which is the anode, set your multimeter to diode test function, and put the positive lead on one side of the diode and the negative lead on the other.
look at the meter and see if you read a "0" or open connection, or if you see a small voltage, like around .6 of a volt.
if you see the .6 of a volt then you know you have your positive lead on the anode and the negative lead on the cathode (banded end).
if you see the "0", then it is the opposite.
hope this helps.
Pulled my diode, unfortunately I see continuity between the ground and 12v when I press in the power switch. Guessing something else shorted out
Kinda narrows it down. Only the pushbutton lights, relay and preamp are powered by that switch. The expensive RF power transistors get their power directly from the power cord.
Any chance that the circuit board has warped and that a foil trace is touching the heat-sink surface? Each circuit board has four screws, and there is a flat washer between the pc board and the heat sink under each screw. If someone gets inside and loses one of those washers, bad things happen.
