...he said the texas star bias circuit was unregulated. This means that as you drive the amp harder, the bias current reduces so eventually when you drive it hard enough, it would become class C, although at low power levels it would be class AB which is what you need for lower power levels at SSB. The texas star bias circuit doesnt even have a bypass capacitor to maintain the bias on audio peaks.
That's right...it is unregulated.
The ham amps also provide an output voltage to prevent the radio from over-driving the amplifier: it only kicks in when the radio puts out too much.
Yeah, the ALC circuit...it allows the amp to tell the radio to cut back the output power because it's over driving it. This is important to help keep the station's ouput signal nice and clean.
