Same pole as in no higher? So the tip of the smaller antenna was lower than the tip of the 5/8 is that right?
How did you determine the reliability of those signal reports?
Yes 24, I figure 2010 compared both on the same pole like he said, and the top of the 1/4 wave was about 15' lower than the top of the 5/8 wave.
That is why the guys that did the real world test in the review...laid the antennas down horizontally about 1 wavelength high in order to help make the difference in height a non issue.
I posted some models once before suggesting what this laying down approach might do for the signals, and all the antennas produced signals that were very much closer to being the same vs. mounting them all at the same feed point height...where the taller antenna has a natural advantage with gain and sometimes with the angle.
That suggested to me,
the longer antenna will still show a little advantage in signal, but just not the big advantage that theory suggest.
It is also likely that 2010's buddies all mount their antennas pretty close to the ground as well. Based on Cebik's list above, the taller antenna looks to have more advantage in getting the signals over obstructions on the Earth when both antennas are mounted low to the Earth.
Mounting 2010's antenna vertically on the same mount is the only reason that he might see the 3 db difference in signals he saw. Like I did, he could have mounted the two antenna at the same height to the current maximums, and then he likely would have seen far less of a difference. The review noted in this thread also suggested the 5/8 wave would not show a 3 db signal advantage in real world testing when compared with the antennas mounted on par and that is why they went to special measures to try and mitigate the effect for the height differences noted.
2010, again I ask, can you tell us how much difference in signals you see compared between these two antennas you mentioned?
I do have a recap report that covered reports 20, 21, 21A, 22, and 23. This recap covered many days of testing. Report 21A reported my A99 mounted at both mounting locations for comparison and the results are noted below.
This group of reports was selected at random, because here I was able to recap signals from
my regular contacts with both antennas at the same height and on the same mount. These 5 reports were taken from other reports, and based on specific data collected from a select group of contacts and the factors noted above.
I selected test for the A99 and the I-10k both being on the same mount. I also selected other test for the A99 mount at my other locations. I compared those A99 reports and one mount reported 7.2 and the other reported 7.3 so I included them too and compared then to my I-10K report, because they were so close.
For information, I averaged the signals for each contact by adding the signals together, and then dividing the sum by the number of contacts. For the summing up process, if there was a sign after a number, I add a .5 to that number for a + located next to a number. I would minus a .5 from the number for a - sign next to the number. These reports with the + or - were noted when I saw the needle very close, but not quite touching the nearest number on the meter.
2010, you've probably already seen this recap below. I might even have a video or two posted somewhere for some of this testing, so you can at least see what I was attempting to do while testing...to collect signal data.
View attachment 091511 Recap Report.pdf
I was really surprised when I totaled this up and saw these two so close. I might have made some mistakes in recording some of this data, but over a period of time the this should all balance out to close to what I saw. This way I don't have to try and just remember what I saw and when I went back an recapped the data I could see the trends without just guessing.
