Hello,
I would opt out on the G5RV it was designed for 20mtr cw,If made for other bands its nothing but a cloud Warmer-it may work ok..The Loop antenna is a good all around
antenna,feed it at 1 end and have it as high as you can get it,Ive had a loop for 160
close in propgation 100-1000 miles works good,it was 1 3/4 waves fed with homebrew
600 ohm ladder line-it had a killer signal on 80,40 and 30 mtrs-Make all your antennas
Resonant to your operating freq. you frequent most.I like Invees and Dipoles too-especially longwire types fed in the center ,end or at 1/4 wave in.from the end a lot of
these antennas require a lot of fiddling with-The antenna is the Heart of any radio system-if your antenna does not play well-your signal in nothing,I have 5- I vees,2
dipoles ,3 verticals and 2 yagis right now,Iam a stickler with the SWR also if not under 1.3 to 1 Ive got to fix it.Good luck and have fun.73/44s/DX
Paul K8PG
Paul K8PG
