The Skeleton Sleeve Fed Monopole
its not convenient as you claim eddie,
please explain how you can have the bottom of the upper 1/2wave well above the radial tips if the antenna uses a 3/4wave monopole and 1/4wave radials?
and don't take a page of waffling to do it.
Marconi, Mr. Reynolds probably didn't update his article because a simple unphased 3/4 wave does not put more gain on the horizon than a 1/2 wave. The non apparent collinear 1/2 wave over a 1/4 wave does. There was no need to mention his article excluded ALL phased collinear antennas as that is just common sense.
Since you like to speak your mind, I will too. Sirio ignores you for the same reasons I should. You flat out called us both everything short of an outright liar many times before we lost patience with your insulting implications. You wonder around aimlessly missing every important detail while you belittle the RESULTS of those who got off their asses and did the tests to confirm CST.
Do you have any idea how rude and ignorant that behavior is when you spew your misinformed opinion over fact? You're glued to a shitty model that doesn't even show the phase delay you see in CST and the field. Did you even own a Sigma? I thought you told us all you had that gold copy with the non adjustable gamma tap???
We should all remember that Marconi has made no attempt to determine if the Sigma is a 1/2 wave or a 3/4 wave phase corrected radiator in the field. He bases all of his "humble opinion" on a model that fails to display what we see in the field but he'll never know this because he's unable to test his ideas or afraid to be proven wrong.
On the other hand, everyone here now has access to a simple field test they can perform on their own by adding the 4 collinear wires to a field testable antenna. When the 1/2 wavelength 180 degree phase delay fails in the field, you'll know EZNEC is wrong. When you cut the phase in half to a 1/4 wave 90 degree shift and it works, you'll prove to yourself it's a 3/4 wave radiator with 90 degrees of phase correction.
Can you describe a field test that will prove your ideas Marconi? Of course not because you cannot prove the impossible. Look in the mirror next time you tell me I only provide words and nothing to back them. Those words describe the field test where anyone could prove you wrong and that's why you have to resort to implying others are untruthful.
Very sad to say the least but you'll still carry on until someone you respect confirms you're wrong. Or you may just stop respecting that person like you've done in the past. Would you trust DB if he ran this test and proved NEC missed a 1/4 wave of constructive current from the cone by confirming only a 90 degree phase delay can stack another 1/2 wave in direct contradiction to NEC?
Would you still be in denial or imply DB was a lair too? If not, I'm willing to supply DB with any parts he may need to make a field test antenna. Things like the base hub and a 2 meter gamma match with some scrap tubing might expedite a conclusion for you once and for all. This is how sure what I've done can be replicated in the field. How sure are you that cone doesn't have significant radiation on it?
Bob, the CST image is the new 3/4 wave Vector with the extended radials you and myself use.
thanks for conveniently not anwering the question again eddie,
you are usually all over the place but i see a consistency developing.
i don't get it donald,
the bottom of the 1/2wave is clearly well above the top of the sleeve to my eyes in the cst plot,
you are right, i measured the image with my calipers and the radials are 1/3rd the total height, the current distribution looks odd to my untrained eyes,
is the model done on a higher frequency than the antenna is resonant on?
Sorry Bob, sometimes I get busy writing my long boring posts, and I loose track of your questions, but at some point down the road I'll try and respond.
Other times, you being so brief in you posts and taking me for granted that I know exactly what you are asking, and always having an answer at the ready, is difficult.
I have to go back and study some post to try and figure out what is going on, and then look back at what has been said, and then try and answer your questions.
Just charge it off to my being slow at my age.
After I sent you an Astro Plane hub I had, did you ever build an AstroPlane like you said you wanted to do?
Man you are slow.:LOL:
Bob may be slow but at least he didn't run his mouth for years about inaccurate ideas before finding out he was mistaken like someone else will in time.
oh shit the astroplane eddie,
the other transmission-line antenna you don't understand,
maybe you could read Barkley and figure it out.
A 5/8 wave antenna is considered by many to be a collinear, simply because it has two current maximums, all-be-it the currents are out of phase. Where does that leave your argument?
Donald, it is probably true that Ballentine considered the 3/4 bad for low angle communications. I said the same thing. You don't seem to even know the history and/or time line for how this all went down. Check the history and the dates of these events in the article. The foot notes are there.
When folks make claims Donald, it is quite appropriate for others to question what is claimed. That is all I did, ask. If a claim proves to be embarrassing for the folks making such claims...I say "so-be-it." If you can't respond to such questions as might arise...except to complain about being asked, then there looks to be a problem with the truth.
Being embarrassed does provide a sense of rudeness by someone to the embarrassed. That is part of the shame felt when we get caught.
You state the obvious Donald, but I use to do a lot of work with antennas. I have clearly stated my opinions are based on my Eznec models. If you have proof that shows Eznec does not work right in this case, why don't you send me your model of a stacked collinear 1/2 wave on top of your S4/NV4K. I welcome someone who can clearly, with good evidence, prove how this antenna really works, including DB.
I'm open to any truth of this antenna...whether I'm right or wrong, and you are only open to your truth for this antenna Donald.
That sound like a good test idea to me Donald...I encourage it too.
Nope, or I would have tried it by now. When I first learned to model, I did it hoping to prove exactly what you and Bob are claiming. I asked Bob to join me in that effort, but he refused. That surprised me.
Donald I changed my mind about the results that Bob told me, that's all. I still believe he told me what he saw. I just can't prove it, and neither have either of you thus far.
Donald are you speaking for DB now?
Of course I would consider what he has to say and report, but he will have to make a better effort than he usually does with his 4Nec2 models. If he does real world testing...I hope to see some real work and reporting...not just words. A good video would also be great too.
Wait a minute Donald. I think I remember, among other objections with the guys on eHam...that you objected to his making a high frequency model to test. If I'm right, and you are having someone else do the testing, are you sure you have a willing participant in DB? If so, I'm anxious to see the work get started.
If you're going to do a real antenna, why do it at 2 meters where line loss could possibly shroud the results, like one of the articles Bob recommends, "The Skeleton Sleeve Fed Monopole" where the author, Richardson, makes just such a claim for a line loss issue in his 2 meter antenna?
I don't use the word "liar" generally...unless I'm passionate and sure. But I do often claim that you can tell what is in a man's heart by his fruits or a lack thereof.
Donald, based on what I see and understand...I don't see much far field currents flowing from this cone.
I encourage DB to take your challenge, do the work, and report his results. I encourage him to also shows us a full layout of his 4Nec2 model of the S4/NV4K that you claim shows the kind of gain advantages you talk about.
I've seen nothing yet that disproves what I've seen in my real world testing using my real Antenna Specialists Sigma 4, and my Eznec models. If that wasn't the case I probably would not be in disagreement with you guys. Yes, I have an original Antenna Specialists version of the Sigma4.
I think I've heard Bob state that his Vector Hybrid used radial lengths that were similar to the radials on his original Vector, and the Sigma 4...they were not extended and less than 100" inches. I'm either right or I'm wrong on the issue about Bob's radial length. If I'm right...then you are wrong in your statement Donald. I rely on Bob to set this matter straight.
I figured the A/P was what you were referring to earlier in another post you made. That is why I mentioned it.
I haven't looked at that model in a long time Bob. If I did it right back then, and made all the segment equal on all three elements in the bottom radial area, I would expect to see a tuner under the feed point, the hoop that transitions the phase of the currents from the tip of the tuner over to the tip of the bottom dipole element. I would also expect to see cancellation between the tuner element and the mast...with almost equal magnitude and the currents on these two elements producing little to no far field radiation so the dipole element could radiate 360* degrees without much distortion in the pattern, and the antenna works beautifully as a very efficient center fed vertical dipole.
When I'm sure of something Bob, I can respond right away, and then Ole Grampa looks fast.
Donald, Bob is not slow when it comes to boosting a 30' foot Vector on his back up a 70' foot roach pole, mounting and tuning the antenna, sliding back down, and testing it out on his trusty CB radio...all within 15 minutes, so the alphabet sky waves don't mess him up.
73ft of scaffold pole + heavy long antenna won't support its own weight,
how do you expect to walk that up and down with big antennas on the end?
you think like those redneck antenna mast installers on youtube eddie,
using 36ft poles untill we realised two pole spaced apart in a field were useless due to interaction/favourable directions,
we would kick the bolt on the stub mast top scaffold swivel clamp,
walk pole down,
pull coax push on connector,
pull antenna 1,
lay down on ground well away @90 degrees,
slot antenna 2 in
push plug on,
walk back up
kick bolt,
2 fit people can do that in under 1 minute pretty easy eddie.
i have been known to shin up 38ft of pole carrying a sigma2 on a 20ft scaffold pole in the pissing down rain in the dark,
i don't think i mentioned the time when my mate fireball slipped & fell about 12ft before his nuts got caught on a swivel clamp,
he was so lucky he hooked up eddie.
Bob, are you suggesting now that the Sigma 4 is not a 3/4 wave monopole?
You are the first person I ever heard make that observation.
walk pole down,
pull antenna 1,
slot antenna 2 in
push plug on,
walk back up
kick bolt,
I haven't heard that version Bob.
That is how I did my antennas, by myself, at 70+ a couple of years ago. I just turned 76.
I just could not do it fast enough, and I had to be careful too.
im not interested in talking about how you did your tests eddie, we saw how you did them and established they are useless for multiple reasons, i don't care what excuses you have for doing it like that,
only a keystone cop would post those videos as evidence of signal performance,
since you are the noisiest negativist im interested your theory of how the vector may work,
a detailed explanation of where and what currents flow equivalent in detail to barkleys paper explaining how the vector is different,
there are other papers out there but your hole is not deep enough yet eddie,
if you know how the vector functions you must be able to explain the difference no propblem,
can you see my issue with the j-pole camp eddie?
10 years and the j-pole camp have still posted nothing but their opinion,
now is your chance to put that right eddie,
where are your links to respected sources that explain in detail so that we may look at the info ?
if you can't do that and prefere to argue when you have nothing to offer by way of an alternative method of operation you could start by elaborating on how you think Za & Zt are just to do with tuning.
i want to understand the antenna and what Cebik meant by
"there is more going on in that design than is immediately aparent to most people"
and why he said the sleeve could radiate in phase with the upper 1/2wave.
