do this testHow do you get rid of motor noise? Had same problem with the cobra handheld hooked to the k-30. Its fine as long as the engine and key is off.
remove antenna from radio . if noise remains them its coming thru your power cord probaly
if noise stops then your antenna is recieving it and can be difficult to cure .
rflimired has a power cord 3 pin that has a filter just for this that actually WORKS
also run both pos/ neg to battery with pos fused at battery
mount antenna on roof
