This is what I've been thinking about.
G-Golly Wally
WDX 719 SE Oklahoma
Nov 5, 2008
537
1,197
153
Southeastern Oklahoma
I have an old V Quad antenna which I actually liked when I had it in the air. But I was thinking about buying a new one, because I ran across some specs for a 4 element delta loop. With two V Quads I would have the option to semi home brew a 3 or 4 element delta loop if I wanted to. Just something I've been thinking about, figured I'd see what the forum thought about this idea.
    Length on matching stubs is critical...Length of rods is part of the overall antenna...Would appear antenna is too Long...same on Both Polarities or different?
    Here's a thought: Could the length of the SS welding rod need to be different than what the broken rod(s) were due to a different Velocity Factor of SS?
  • @ Jim5570091:
    Close to the same. Thats the rout I was going. But needed a second opinion. Thanks cranking the hazer up and down testing was getting to an old man. Upper 90s here. Cheers 297 The red dog north Alabama.
  • @ Jim5570091:
    Maybe. I wasn’t impressed with just clamping the shield wire to the boom with a hose clamp. I built a l bracket with so239 female hubs. I posted a picture on the recent gallery’s.
  • @ Jim5570091:
    Well I cut the matching stubs down 1 inch at a time from about 20” down to 6”. Still no real changes.
