I'd agree with KingCobra, and just add a little to it...
An antenna -like the IMAX2000- will cover pretty much all of 10-11-12 meters. Some say even 15-17-20 meters. but it certainly does 10-11-12 thing for sure - and WELL. Many claim that it works all bands between 10-20; but that just isn't so. It may work; but it isn't really resonant on anything except 10-11-12 meters. Lotsa noise, and acts more like a dummy load on 15 thru 20 meters. Three bands from any antenna is all one should really ask for and expect - IMO.
Any antenna that claims to do it it all is still going to be more resonant at only a few points. Even the dipoles using a tuner have great limitations, db gain is pretty small, is generally horizontally used for DX, and has a lot of nit-picky setup requirements. Height above ground (VERY expensive towers - if necessary), angle of propagation, and any large metal objects nearby will affect them. Paying $100~ for a 10-160 meter G5RV and then paying for $450 of Andrew/Heliax just ot get some gain on a few bands is just plain expensive. For the amount of potential money spent -in my book- doesn't justify the return. Better off with a triband yagi w/antenna rotor - but at l e a s t you can see r e a l gain numbers. Most practical solution that I've seen so far. Anywhere from 7/10db can be had from most yagis, and is certainly ahead of the rest of other designs.
If you expect the Titan DX to do 15-17-20-40 meters; you may be disappointed. It's best gain is really 20 and 40 meters, although it can do others. Just not very well. At best, it can muster 3-4db on 20 meters, and then flattens out on 40 meters to -2db. So long as you keep with the instructions and install it as specified, it's OK. It is also vertically polarized, which is better for DX. But if locals are using horizontally polarized antennas; signals will be weaker in recieve/transmit when using a vertical antenna. Nature of the beast - the difference between horizontal and vertical polarization will have that effect.
Many Hams use multiple antennas so that they pick/choose the antenna with the best resonant frequency for which they want to operate. Trade-offs and compromises are inherent to any radio bandwidth. Anybody telling you that the antenna they are selling you gets huge amounts of gain on every band, turn around and run in the other direction at full speed.
Just two cents...
Performance Test Results:
Gain of GAP Tital DX compared to monoband reference antenna:
*** 80 meter results will be forthcoming.
Band: 10m 15m 20m 40m 80m
Titan DX, Average -11.0 -7.8 0 -7.6 n/a
Relative Gain, dB
Reference Ant 4.89 4.68 4.54 4.62 n/a
Gain, dBi
Reference Ant 10 10 10 10 n/a
Launch Angle, deg.
http://www.qsl.net/aa3rl/titan.html
