TNT HD 600 amp
Turbo T
Certified CB Rambo
Feb 2, 2011
963
142
53
TNT HD 600 amp. In good shape. I used a Magnum 257HP radio to drive this amp, and with a 108 whip, I could get my numbers called on channels 11, 20, 26, 28 and on 38 LSB I was known to cause a pile up! This is a straight 4 transistor amp. Asking $325 shipped anywhere in the lower 48 states. Sold as is. First come, first serve. I accept Paypal.
Here are the specifications on this amp from the Xforce website:
Transistors 4 x 2SC2879
Dimensions H 4 3/4' x L 11' x W 6 3/4'
Amp Draw (maximum) 100
Class B biasing
SSB Delay yes
Pre-amp yes
Driver Required T100-M
Max Dead Key 200 Watts
Modulated Power (RMS) 300 Watts
Modulated Power (PEP) 625 Watts
Modulated Driven Power (RMS) 400 Watts
Modulated Driven Power (PEP) 1000 Watts
install recommended with 4ga wire and 125a fuse.
Max input carrier of
10w or 200w max carrier from amp.
Max peak input 240w.
