Frequency Band 300-699.9 MHz
Horizontal Pattern Directional
Antenna Type Yagi/Corner
Electrical Down Tilt Option Fixed
Gain, dBi (dBd) 12.1 (10)
Frequency Range, MHz 406-420
Connector Type RG8A/U N Male
Connector Location Bottom
Mount Type Fixed
Electrical Downtilt, deg 0
Horizontal Beamwidth, deg 50
Mounting Hardware U Bolts .3125 in. (.008 m)
Rated Wind Speed, km/h (mph) 160 (100)
VSWR < 1.5:1
Vertical Beamwidth, deg 40
Polarization Vertical
Front-To-Back Ratio, dB 15 (min.)
Maximum Power Input, W 250
Lightning Protection Direct Ground
Impedance, Ohms 50
Dimensions - HxWxD, mm (in) 406 x 1397 x 102 (16 x 55 x 4)
Weight, kg (lb) 2 (3.75)
Element Material 0.375 in. (10 mm) 6061 - T6 Aluminum Rod
Max Wind Loading Area, m² (ft²) 0.033 (0.35)
Survival Wind Speed, km/h (mph) 200 (125)
Torsional Moment @ Rated Wind on support pipe, N m (ft lbf) 33 (24.5)
Wind Load - Side @ Rated Wind, N (lbf) 62 (14)
Shipping Weight, kg (lb) 3.6 (8)
Packing Dimensions, HxWxD, mm (in) 1524 x 1448 x 406 (60 x 57 x 16)
Shipping Mode UPS
Notes
