The Retevis Holidays giveaway winner has been selected! Check Here to see who won!
Top Gun Modulator MD-1 and Compressor CP-1 check this out
Yeah, it shows that it's over modulated. A little over modulation can sound pretty good on AM, but there is such a thing as too much. At least the negative peaks are still there in that pic.
The Magnums I seen when the topgun on is way more overmodulated than the scope form in that pic. Compare it to a well tuned galaxy. The galaxy looks alot better. Same power output as well. I saw a Cobra 29 with a 2SC2078 doing 32 watts yesterday that looked better than the magnum with topgun on a scope!
Sine wave demonstrations tell you nothing about how a dynamically controlled circuit will respond to complex (voice) waveforms... How long was this sine wave applied before the pic was snapped? Just because it is not clipping in this pic does not mean it will not clip with voice.
That said... the most important tool to achieving louder audio is a clipper! True... clipping causes distortion but if done correctly, quite a bit of clipping can be applied before that distortion becomes offensive. Don't take my word for it, hook your scope up to your AM/FM stereo and see what the professionals get away with.
You're right, Riq...actually we had a pretty lengthy thread a while back about negative peak compression and one of the topics was about how it's used in broadcast audio stations.
Need help lost my channel chart . Cobra 148 GTL with a 8719 and 11,1125 crystal 26.175 to 28.045 , Need the chart I can fill in the blanks slide 2ck up and 12 kc down
