J
jbno7
Guest
I owned both Astro Plane and Star Duster Antennas back in the 70s and 80s. In my opinion the Star Duster well out performed the Astro Plane in both TX and RX. The bad thing about the Star Dusters is that they were pretty dirty, even with out an amp they caused a good amount of TVI, and with the amp, forget about it. I also bought an after market Star Duster that Signal Engineering put out in the late 70s and it did not perform as well as the original antenna and it was cheaply made, it only lasted a few months and the wind took it apart. I like the A-99 if you want a good performing cheap antenna and your not going to run much power throught it. I recently sold my I-Max2000 and put an A-99 back up. The A-99 has better ears and the TX is the same. The I-Max2000 is overated .Put up one of Jay in the Mohaves antennas, as I have heard nothing but good about them. Thaaaats what Im going to do in the spring.
"the only scope in that dc communications trailer is to cover up the crack breath.."
</p>
</p>
