It's a POS!! It's only 3ft tall. Don't expect much at all out of it!! About like using a coat hanger. Your better off looking into a dipole in your attic or even looking at the dual firestick dipole. But IMO. I wouldn't waste my money on that TRAM 1499 antenna. You can't make yup for physical height of the antenna itself. A 1/2 wave antenna is approx 18ft long. The one you snow there is only 3FT long. Just a big waste of money. JMHO. Look into other options. Shoot even an A99 painted black doesn't stick out much at all. I too live in an HOA, but I also just put an antenna up and no one has said anything for 3yrs now. And it's a rather long antenna. But no one has said a word about it. Mounted it in the back yard onto the side of my chimney. Base of my antenna is at 27ft. Antenna is a sirio vector 4000, and is almost 28ft long. The antenna itself is. Anyways. Might try doing some more research. The firestick dipole seems to work for some as does a dipole placed in your attic. Be better than that antenna you posted IMO. Even locally.
Hope some of this helps. Good evening.
