TS-570D Low output power
Hello! According to all the manuals found, the microphone connector indicates that there should be 8 volts on the 5th leg, and in mine 5, more precisely 4.8 volts. Is this a bug or a modification? Thank you! 4L6FU
  • @ Geoexplorer69:
  • @ Geoexplorer69:
