Click here to find out how to win free radios from Retevis!
If I understand your question correct.
You have a antenna that covers 10/15/20 meters and you want to use it on 40 meters with a MFJ manual antenna tuner.
The answer is Yes as long as the tuner will take the 100 watts output of your radio.
The Antenna will not be as efficient as a antenna that is properly cut for 40 meters, but it will work.
You may burn up- any traps in your antenna running it that far out of the design bands. The RF voltage will be quite high for sure. The efficiency will be abysmal as well.
I know that it will be dismal on 40, but at 100 watts Input did not think the voltage in the traps would be that bad.
You have more experience than me Capitan, I stand corrected.
I didn't want to assume he was just running 100 watts nor that the antenna was rated at the standard 2 Kw pep. Some tribanders are only rated for 600 watts
on3bm.be on3bm.be
Enjoy the pictures and make us happy to click Marcel's WEB button
Marcel: Some very nice, Interesting pictures on your website.
Hope to hear from you "In the Air" soon on 40m!!
We may have worked in a Contest. I help operate some contests from W8PR/Ohio.
Recently operated the CQWW SSB contest from there.
All the Best OM
Gary/W9FNB
PS: The "Lazy H" laying horizontal (W8JK) works very well. I have one up I use on 80/40/20 fed with a manual tuner and 300-ohm twin-lead @40+ feet (12m +/-).
One more note Marcel: Your rotatable dipole for 10/15/20m is basically the driven element for the A3S beam. They do sell a 40m add on kit for this antenna, this may be an option.
This kit adds 40m to the driven element, making it a rotating dipole for 30 or 40m!
