My only HF antenna at present is a 450 ohm ladder line fed doublet with 66 foot legs and hung as an inverted V. It works quite well for a simple wire antenna. I bring the ladder line into the basement directly under the shack and connect to a homebrew 4:1 balun (keep meaning to change that out to a 1:1) and then about 10 feet of Belden 8214 coax cable to the shack. Although it does not work as well as the tribander did it is in fact an all bander and I don't have to rotate it. After I finish with some major antenna work this summer I may leave it up as a 80m antenna or as a backup.
