Turner +2 mic battery
I have a turner handheld sidekick 60. It is wired with a din realistic plug end. It is black mic with white printing. I cant read the lettering on the battery because it is rubbed off. I would really like to use this mic again. Can I assume this mic takes the same battery or batteries as the +2 and +3?
If you're thinking about the Turner Road King 60, yes that one takes the same battery. Same mic, but with a different label in a black case.
I made one yesterday for my M+3B. 5 cells + 1 small brass washer to get the length right, gotta make sure that you have adequate contact pressure (?).
Five LR44’s with the 3/8” heat shrink come out perfect and much cheaper, but I get that some will not want to assemble them by hand like I do. Last time I ever bought any commercial made batteries I was unimpressed with them overall. But, hopefully others have better luck with them!
Reactions: Smokinone
