I did a search and didn't see any recent posts on this one so I thought I'd start a fresh one. By choice I'd gone all my ham life since 1993 having only 2 meters as a base or mobile. I figured I'd have all the talking I wanted to do on 2M and dual band radios cost twice as much and the antennas are a bit more as well. I have a good local friend who has a 440 machine and decided I'd finally upgrade. Went with the TYT TH 9800 Quad Band mobile for $200. The specs seemed impressive and you can't beat the price. They did quite a bit of copying of the Japan designs. Physically it's the same size as the Icom 2300 I was using. Used the same quick connect power cable so didn't have to change the cable half coming off my power supply. The width and screw holes of the mobile mounting bracket were exactly the same as the 2300 and the 2300's bracket sits the radio better on my setup so put the 2300's bracket on the 9800. Is 50W VHF and 40W UHF in 4 steps. Is ham bands only out of the box but will have a buddy coming over with a PC laptop to perform the Expansions via software download. Came with the programming cable. This thing has every programmable feature you could ask for plus some more. Audio quality is excellent in & out. Has a cooling fan on rear heat sink. 800 Memory chs in all kinds of configurations.
After mods will:
RX 26-33 AM/FM & TX FM
RX & TX AM/FM 47-54
RX 108-136 AM
RX & TX FM 136-180
RX & TX FM 320-512
RX FM 750-950
Can program memories with Chirp but I went ahead and manually programmed my usual list as Chirp wasn't available to me on the spot. Very decently written large-size manual that was easy enough to follow. Like any new radio there's the learning curve to go through the manual but I didn't find it that difficult.
This radio is a scream for a lousy $200 bucks
Have the Diamond X510 17' dual band base antenna coming Friday. Is 3x5/8 on 2M and 8x5/8 on 440. Can't wait to see how much better that works then the 2x5/8 2M ant. I have now.
After mods will:
RX & TX AM/FM 47-54
RX 108-136 AM
RX & TX FM 136-180
RX & TX FM 320-512
RX FM 750-950
