I was thinking the same thing. Total waste of good bipolars.I hope you have enough spare drivers and finals to get the job done ...
Ive heard that. I dont have the second gen to compare it with. I know that they removed that little board in the back of it. Thats all I know about it. Without a schematic its been a real treat NOT finding my way through it. Lucky its the finals. Simple layout. Id hate to have to figure out the oscillator path for am and ssb on this. Tracing it all through to wherever the pll is located would be a nightmare. Have you heard of a drop in fix? Someone sent me the pres mckinley sm but its completely different from this one. Maybe the same as 2nd gen but again, I dont have one.You do realize, that the Mitsu final is no longer used in the current production units?
Could be a waste but maybe all it needs is a 1306 and 1307 set from an old 23 ssb. Vcc is the same, ground is ground, a littlr biasing and a coupe of protection diodes across the finals just might work. I got spare parts and im retired so it'll be a winter project.I was thinking the same thing. Total waste of good bipolars.
So true. I find that there are a lot of really good features on it and the ears are remarkable. The pots are kind of fragile it seems. Only bitch really is the mits rd16hhf1 and thats because the mosfet has poor internal protection. Maybe the old diode trick between the drain and source in reversed hook up might save the chip from frying if it forward biases the diode but then the diode may short and let the smoke out of the mosfet anyway. I dunno. Im still thinking of ripping that crap out and slapping in old school bipolars.i got 2 of those cheepo radios
sadly if uniden woulda invested a itty bit more $$$ they could built a best radio.
i removed 1 from service in 1 of our big trucks that couldnt take it . not used much either. as soon as i finde right radio the other 1 is coming out of truck #2.
if somebody dearly loves these radios id gladly trade em off or sell em
Perhaps you can find internal photos and compare them visually. The newer final is an equivalent of the IRFZ24, which seems to be robust and dirt cheap.Ive heard that. I dont have the second gen to compare it with. I know that they removed that little board in the back of it. Thats all I know about it. Without a schematic its been a real treat NOT finding my way through it. Lucky its the finals. Simple layout. Id hate to have to figure out the oscillator path for am and ssb on this. Tracing it all through to wherever the pll is located would be a nightmare. Have you heard of a drop in fix? Someone sent me the pres mckinley sm but its completely different from this one. Maybe the same as 2nd gen but again, I dont have one.
Bias voltage/circuit and input/output impedance match, will most certainly be different. I think it is easier to go from bipolar to MOSFET, than the other way around.Could be a waste but maybe all it needs is a 1306 and 1307 set from an old 23 ssb. Vcc is the same, ground is ground, a littlr biasing and a coupe of protection diodes across the finals just might work. I got spare parts and im retired so it'll be a winter project.
Cool to know. I'll look it up. But get this. I bought 2 10 packs of the rd16 type. Completely different sellers. 1 on ebay the other amazon. They were blowing my fuses. All tested good on my transistor/mosfet tester. Not 1 of them worked. It is a complete rip off true, but it has me wondering how they are soooo capable of faking the test gear....Perhaps you can find internal photos and compare them visually. The newer final is an equivalent of the IRFZ24, which seems to be robust and dirt cheap.
They re-mark transistors that are working as they were intended to. Just not in your application.Cool to know. I'll look it up. But get this. I bought 2 10 packs of the rd16 type. Completely different sellers. 1 on ebay the other amazon. They were blowing my fuses. All tested good on my transistor/mosfet tester. Not 1 of them worked. It is a complete rip off true, but it has me wondering how they are soooo capable of faking the test gear....
