yeah, i never had one that was this restricted. usually can pull it back to about 2W and it screams
Just some random going thru old electronics-i repair pretty much any newer electronics and i found one of these (or similar at least) from 1988. I know its either junk-or someone would prolly kill for it and its parts. Best i can tell it works fine, looks undamaged,Keep me posted if - in case, something develops...
well, does it fire up?Just some random going thru old electronics-i repair pretty much any newer electronics and i found one of these (or similar at least) from 1988. I know its either junk-or someone would prolly kill for it and its parts. Best i can tell it works fine, looks undamaged,
Just wondering, something from 1988 like this that i can barely find info on could be invaluable to someone in need... Just doing my part to help others out here. Shoot me an email at skylarr12227@gmail.com if its not junk-if it is dw about it and ill toss it in a week or so.
Thank you very much for that information. I went ahead and did that to my wife's good working Uniden 122. Added the 2.2 ohm resistor in series with L32, then did the 180 ohm resistor on VR9 to the circuit board ground.To help with Bias...
My main beef has been R172 not having a way of dividing down the 8 volt TX current power load - for when it's driven hard, the Bias itself can climb - and can blow the Bias diode (MV-1Y) by doing so - from too much Bias applied, and SSB signal driven hard during a QSO with the ALC turned nearly off - not effective - against strong output from the TX strip.
If you have to do it (run it) that way...
Might as well install a divider to offset some of this voltage....got a 180 ohm resistor? Install it across R172's leg to the Driver just past VR9 (not L32) to Foil Ground
- - Not chassis (Case) ground - Board POWER ground.
Follow this as an exampleThis can help go a long way is preserving the Driver from self-destruct caused by Bias 8 volts not having anywhere to go except to SUM into the RF arriving from the Predriver. Too high of voltage - either by bias set for too much current or from excessive drive, the current can rectify and damage the Driver permanently.
Whether it's a Cobra SSB or Uniden SSB radio
Realistic or otherwise...
Locate VR9 and R172 install a 180 ohm 1/4W
resistor from the junction of the VR9 output to R172 and Foil Ground underneath VR9
The graphic on the left is for Cobra SSB radios that have Driver VR pot located just before the Bias Diode.
Is it necessary to re-adjust Bias?
You should verify that there is 50mA OR LESS at the Drivers TP jumper,
then you're set. Reduces the chance for a catastrophic Driver failure.
Kinda' (Or Very) IMPORTANT!
Locate TRC-453 - R 195 (2.2 ohm) resistor
See how it is installed ...
- L32 on one leg to take place of L32 as two parts.
You may want to install resistor there at L32
keeping L32 on one leg reinstalled to
LOWER Bias Drive and to keep
BIAS and RF power away from each other.
