It's parentage sometimes confused with Yaesu (the Tempo One was Yaesu) and the Uniden applied to other than the US radio which was Henry, The 2020 is an interesting Hybrid in two ways. First it uses the 12BY7A driver and the 6146 pair as do many other Hybrids. Second is the curious Hybrid synthesizer that not only uses a dial for the last digits but spans 100KHz in 5 steps. The Yahoo group dedicated to Tempo 2020 is a great resource.
Now onto the "fun"
My 2020 came to me with a broken sprocket set. This makes the radio useless. With many thanks to Wald, N4PL and Gregory, NR6C I proceeded to restore this radio.
This is typical of ALL of these 30 plus year old radios . There have been adaptations of other sprockets and temporary fixes that used small clamps, tie wraps, tie wraps and glue or circlips. Forget about it , all of it . f you are going to get into the radio at all, do it right.
A thing of beauty. These are 3D printed and machined centers. They are made from a much more stable plastic and should outlast the radio or operator. My only suggestion to to Greg was to include a couple extra setscrews as they are easily lost. It is so very rare these days that you can close your eyes, sign the check. and be happy. That is exactly what happened here. The ID of the sprockets was so close that minor stoning of the shafts was in order to remove burrs from the original set screws.
As you can see if just one of these sprockets is off the radio is essentially junk. I'll admit to having to do the install no less than three times as I was "one off" the first two times. I got pretty good at getting into the front of the radio which I'll share next .
Many thanks to W7CPA, N4PL and NR6C for the images and text
W7CPA here
http://www.arizona-am.net/PHOENIX/W7CPA/Tempo 2020 Restoration Notes.pdf
NR6C here
http://nr6c.com/TEMPO SPROCKETS.htm
N4PL here
https://groups.yahoo.com/neo/groups/TEMPO_2020/info
Now onto the "fun"
W7CPA here
NR6C here
N4PL here
