US WWDXers: Will you be getting a FM rig?
Will you try FM?
  • Total voters
    38
I can see a CB modification opening up to add FM to all these old AM only CBs, if somebody doesn't have it already. I already own too many old but good CBs.
Not sure just how easy to convert an AM only CB to FM is. I do know that the preferred rigs to convert to FM for use on 10m were SSB Cybernet chassis units. They were quite easy to convert. Note I did not say add FM but convert TO FM.
Reactions: whiteastro
LM3089 FM Receiver (since discontinued) only needed one adjustable inductor (discriminator) silly simple.
Later there were a handful of two chip solutions you could use.
Most accepted a 10.7MHz input and actually had too much audio gain.
Transmit was via the usual (and nasty) placing a bit of audio on the otherwise named "clarifier" circuit or going through the bother of a proper clipper/limiter/processor before yanking on a varactor.
worst part of the install was finding somewhere to put the switch :-)
