V-QUAD or 3 ELEMENT MAX. BEAM?
Red Ranger
150
3
Which antenna would work best(performance) on a 30ft push up pole?
I notice that the V-quad has a "Stacking Kit available" at Copper. Just how far would one need to separate antennas to stack them properly?
Looking at the stacking kit, the antennas are not that far apart. I was under the impression to properly stack, you need a 1/2 wavelenth of separation.
http://www.copper.com/cart/popup_image.php?pID=1578
So if I was to stack a pair of V quads, can I just use a Cophase wire harness to cophase the two antennas?
inmh id just go with the m-103 on the flaty side.if ya already have a stick
if not mount this oner verticle.until ya can get a ground plane.then mount
the 103 flatside.just my personal preference
3 element maxi beam is a good beam gives both horizontal & vertical why pass up on the best of both when Dxin can't go wrong with it. i never had the V quad myself but one thing i do know they are a sleeper giving great dx performance i know a guy that has one and has talked all over the world straight out of his Realistic TRC 457 on SSB and had the Qsl cards to prove it. the 3 element Maxi Beam & the V quad are so close in performance its a flip of the coin or which one looks beter to you. those V's are kind of snazzy stacked.
