Ok. Check at feed point and try a different power supply maybe. I got this antenna many years ago. Maybe it is not a Vector. It does have the four radials with the hoop but it is made out of (the best way to describe it) corrugated aluminum. No hat on the top of the whip and the whip is adjustable with a set screw and is about .5 inches diameter. Maybe I am using all the wrong lengths. Is that a possibility? Although it seems the dimensions for a Sigma or Vector seem pretty close. And I did set it up to the old marks. Could be some confusion there though, previous owner used it on 10 meter and I am on cb. I do want to thank all of you for responses so quickly. Gives me directions to go. It just seems really funny that at first I could calibrate and then bang couldn't. Really threw me.
Sounds to me like the old CTE version of the LW150, and it was a problematic antenna in my opinion. I think the tubing was screwed together using two sheetmetal screws as noted in the attached manual, so only the top element was intended to be used to change frequency from 10,11,12 meter. The manual does not discuss the gamma at all, even though the gamma may tune well tune the antenna any particular length within reason.
I attach what I have that might be the manual that went with this antenna and it is slim to none informative. Note there is a hand note on the tip element being 47.2" long and I assume that is for 11 meters. There is another dimension on the sheet as well. If this sheet does not look to be for your antenna then ignore it.
View attachment IMG.pdf
Like I said, IMP these instructions show the correct length for the tip, and I believe the guy I got this from was intending it for 11 meters, maybe around the high end, but 11 meters. The balance of the antenna should be screwed together for the default length. Like I said, I don't think that CTE intended to adjust any lengths except the tip and the gamma. Same goes for the radials. IMO they were not intended to be adjustable. This is not to suggest they are not, but just to say the antenna was intended to be setup for 11 meters and if you wanted to set it for 10,12 meters, you were on your own.
View attachment IMG_0001.pdf
The dog bone connector for the gamma to the radiator is centered here.
One thing, make sure that the gamma is as close to spliting the difference between the two radial legs it is mounted between. If it is not right the tune may be hopeless.
