Exactly, 2 simple quick and easy fixes. I vote for slotted tubing and clamps, solid, time tested and will stay put.I had a Vector 4K 25 years ago, and IIRC there were 2 self tapping screws at the join of each section. Looks like the small holes for the self tapping screws have become elongated with stress of moving around in the wind over the years. This will have shortened the antenna and increased the SWR.
I would either turn each tube 180 degrees and drill 2 new holes in the back of the appropriate size or, go with Shadetrees idea and cut a slice in the end of the tubes and use hose clamps.
