I am about to pull what little hair I got out over this issue. I was told that I have a great carrier but my modulation is very weak. PC Board EPT360014B. So heres what I have replaced so far (Now being I bought this radio a few months after Galaxy discontinued it). All parts were replaced with what was on the part list on CB Tricks.Com
1. Replaced IC8 the Audio Power Amp with the factory TA7222AP
2. Replaced TR41 2SA1869 Voltage Regulator
3. Replaced TR51 2SB754Y (What was on parts list) AM Modulation Amp (Component that was removed was a 2SB827)
4. Replaced TR50 AM Mod. amp 2SA473 part list showed the 473 but when it was removed the component was 2SA1869 which is the better component.
Still the same problem very weak modulation. Now I am going to throw this out there could it be a weak 2SC2166 driver and the Pre Driver 2SC2538.
Wanting to put the radio back on the table so I can replace the lamps in my Magnum 257. If anyone knows where or what type of lamps I need to get please let me know.
Any help would be appreciated
Thanks
Thanks
