I did try t adjust but it still did the something there's got to be some component that's going bad or getting weak and hasn't gone all the way out maybe radios can sometimes make a preacher cuss when things go bad.Definitely sounds like it is in need of a TX chain alignment. Off the top of my head, I believe it's L44, L43, L42, and L40.
Replace TR51 with a TIP36C.
Replace TR50 with a TIP42C.
Replace TR41 with a TIP42C.
These transistors are much beefier than the originals. They are also more cost effective too. This isn't necessary, but helpful, and you will see more output, if the radio is aligned properly.
The TX chain alignment is necessary, though. As Robb suggested, you'll need something that can produce a steady 1khz tone, a ceramic or plastic screwdriver, and a good wattmeter. Adjust those 4 cans and that should net you more output, IF they are out of alignment.
My Superstar 3900G had the same issue as yours until I did a good TX alignment on it, now it does 50W PEP on SSB and has excellent forward swing on AM.
Good luck.
~Cheers~
I don't have any type of alignment equipment a tone generator a scope all I got is a watt meter a dummy load and a digital VOM
Bad thing is there's not a shop within 65 miles of where I live to take it to I dont knoew might start looking online and ship it off to a tech to get it repaired my old hands and eyes aren't what they use to be
