Sonar you have a great 4th also!
make sure you store that Madison where you can see it. otherwise you might end up going through withdrawals!
Kaos, take a look at building a "half square antenna". It can be hidden really easily, can be fed with 50 ohm coax without any tuner needed, and is meant to be at ground level.
This may or may not be feasible at your location, but it's worth looking into.
