Video Of My Hi-Fi CB.
Rob is right, There is nothing there for cb radio other than they use a Ham radio and you use a cb radio.
Theres a lot of info useful info there to setup your audio chain once your radio has been modded to pass wideband audio.......At lest I found So
Well, if the person on the other end has a receiver with a narrow rx bandwidth they probably can't tell the difference between lo-fi and a regular hand mic.
I was thinking about this and I can definitely hear a big difference when listening to the guys with the wide band radios coming over my stock CB...like "Bass master"? :)
  • @ Geoexplorer69:
  • @ Geoexplorer69:
