voltage drop.. is this normal
Since this thread started off with a 500w amp as the issue, I think that improving the wiring and adding a stiffening cap would help a lot.
But he didn't say what kind of antenna he was using either. If he did; I missed that part. Sure wouldn't want to run a 500w amp into anything smaller than a 1/4 wave steel whip or a Predator Freedom DX-K Fighting Stick. The antenna is always at the other end of the efficiency chain . . .
Well I've been looking for some good 2 gauge wire for some time know with no luck . But can't find any I'm my area. I have a spare battery laying around I'm goin I addthat. In the amp line and see if that helps but still planing on runing 2 gauge wire when I find it
With out engine running 12.5 volts. With engine. Runing holds 14 volts
With connex 3300 an Texas star Dx 500 I've seen as low as12.3 on long keys
My truck is. A 1999 Ford superduty 2 1000 cold cranking amp batterys
I'm. Runing 10 / 2 house wire for power wire. Would it be benifical to upgrade to 4 gauge
Do you guys think that would help the voltage drop
the reason you see voltage drop is the alternator outputs a higher voltage than the nominal battery voltage.
the smaller voltage drop between 12.5v and 12.3v is due to the battery discharging high current relatively quickly, same thing causes you to have to push start when you've been listening to the in car hifi too long or had the heating on without the engine ticking over. when the engine is running the alternator NOT the battery is supplying the juice.
so yeah beefing up the alternator might work as long as you leave the engine running during tx, but it will do nothing positive if you are tx'ing with the engine off.
no high power linear user sits for any length of time with the engine off, unless he's keen on pushing his car or is parked at the top of a hill.
stiffer wire won't make much difference either when the engine is off, your voltage drop between battery and amp is minimal anyway, 0.2v, not a huge amount,
stiffer wire might help when the engine is running, but again it depends if the alternator is putting out 14v. or slightly more and your measuring it at the lossy end, if you measure it at 14v right at the alternator and at the amp during tx it tells you you ain't having much voltage drop with your current wiring.
a good guide for wiring is too use wire capable of carrying at least twice the current you are using/requiring, keep it as short as possible, and fuse it at the battery end for safety, use the best quality connectors/fuse holders/fuses you can find, my favourite is the gold plated AGU in car hifi types.
when you cut corners at high power levels many problems can occur.
here's a link to a guys web page with a good insight;) how the alternator/battery system works, well worth reading if you intend running high power:
www.bcae1.com/charging.htm
I am currently waiting on my local parts store to get me in a 25 foot spool of 2 gauge wire
It was soposed to be there last monday
How about heavy speaker wire?
mechanic
No where near heavy enough. Even 14 or 12 gauge speaker is considered quite heavy. Even monster cable which is 8 gauge or so is not heavy enough.Most of that cable looks big but is really small with a thick insulation making it look huge. Automotive shops or as said before welding shops will have good sizes. You would want at least 2 gauge to make a difference that counts.
there really isnt any welding shops here. im planing on ordering some on friday if i cant find any here . i am going to do the big 3 upgade as they do in the car audio world
