Voltage drop
Any and all thoughts and suggestions are welcome. Just installed new cap bank and diode board. Going to fire it up in a bit. See what happens.
Well I saw a bright flash and heard a loud BANG!!! but I guess it wasn't your amp. Turned out to be the 480 volt 1500amp three phase slip rings on a machine at work. Second time in less than 12 hoirs. First machine just welded the brushes to the rings. Second machine is down a couple days. After we put the fire out we started looking for missing pieces. Better wear eye protection when you plug that beast in.
Its up and running. Making a few last minute modifications to bias. But amp is up and running. Did a 250w carrier and it swings up to 800w average. Over 1600 pep. Bias had 15v of bias, but I'm putting around 18v now. It should run a bit cooler. I was driving it with a pair of 1446 transistors. Its a lot of drive, but I wanted to make sure it will hold together. Also after I'm done. Will install a 10k -15k resistor across diode bank in case it fails. It has a 1.5a fuse, he has blown it at least 10 times that I have known. So that is why I am adding a bit more bias to calm it down some more. Plate sits at 3kv and drops to about 2700vdc under load.
  • @ W4KVW:
    Rock Stars ROCKS!
    Looking forward to it Gary!
