shockwave i think if my memory serves me right it was this one =look at the image
Thanks Willy. That's not the Radio Shack choke I use to install but, it probably works just as well. I agree with keeping the AMC intact since bypassing it can cause every stage from the mic preamp, to the output chip to flat top.
For the customer that was difficult to please without removing the AMC transistor, I found another way to modify the AMC circuit to prevent the AF stages from ever going into distortion while still allowing the full modulators capabilities. It is especially useful if there is real NPC installed.
The idea is to take the input line from the AMC circuit, off of the RF line and connect it to the output of the audio chip. That input to the AMC circuit was off a glass germanium diode but I did forget the number. Now the positive peaks can rise to the full potential of the modulator, regardless of the carrier setting. AMC will only trigger to prevent the modulator from flat topping. If you can prevent the negative peak from hitting cutoff, this will produce louder audio without noticeable distortion.
I'll also mention that when you "volt" the final with only 12 volts and no modulation, you may hit 20 watts of output. However, when you modulate that 12 volts, the peaks can easily hit over 40 watts PEP. When you double the modulated voltage to the final at the same output impedance, output PEP tends to quadruple what it was at 6 volts. The stock 1969 final, will not like this at all.
