In Menu 1 you can adjust the AM TX Bandwidth to 4.0khz ..... but this doesn't affect the audio tone. Is there another menu selection to deepen or make richer the AM Audio sound? Thanks
No help guys. Have already done that. Asking about changing the sound of the Audio Out.
Hi Greg .... but you keep referencing the 955. The 655 does not have this choice. The 655 has fewer FUNCT/Programming/TEST choices as it lacks SSB, and some the Features offered in TEST on the 655 are on different numbers than the 955.The menu DOES change the sound of the audio if you choose RX and choose 4.0k
I'm aware that I can change the audio tone with an equalizer etc ..... ThanksWhat microphone are you using?
Then you'll have to replace some components.Hi Greg .... but you keep referencing the 955. The 655 does not have this choice. The 655 has fewer FUNCT/Programming/TEST choices as it lacks SSB, and some the Features offered in TEST on the 655 are on different numbers than the 955.
Is the 655 that different from the 955 on audio circuit design?No help guys. Have already done that. Asking about changing the sound of the Audio Out.
Just exploring the menu adjustments. I am surprised they left the option off the 655 while including it in the 955.I do not know anything about the 655 not heard one on air yet. That said the Stryker 955 has the best AM audio I have heard on a radio marketed to the CB world in the last 20 years maybe more. Being an AM only radio as in not having SSB I would imagine it's AM audio would be fantastic? Does it need "different audio" through the menu?
Is this just you exploring the limits of the radio or is the stock audio crap? It might be defectives.
Good Luck hope it works out for you!
I would agree with you. And the 655 is actually AM and FM.I do not know anything about the 655 not heard one on air yet. That said the Stryker 955 has the best AM audio I have heard on a radio marketed to the CB world in the last 20 years maybe more. Being an AM only radio as in not having SSB I would imagine it's AM audio would be fantastic? Does it need "different audio" through the menu?
