WDX Roster
Peddler
SWR (sandwich with rum) Expert
Aug 6, 2001
2,457
11
48
Central Texas, USA
Here is the WDX Roster:
Please include your first name, town (if you fell comfortable with that) and State / Province when requesting.
I will make changes as needed...please check your listings and reply to this thread with any changes.
Edit by Binrat
Last Mod: Apr 6, 24
  • WDX 30 June.xls
If you can't open the file I found that by using Works spreadsheet it can be opened. Open Works spreadsheet, click "file" then open. When search window opens go to bottom and choose "all files" then go to c:Windows\temp and locate the file. Then open.
If you do not have Excel but have WORKS Spreadsheet it is a better format than the TXT. file. I just put the text file up in case no one had a way to read the xls file.
I'm still in the same spot. CDX-443 Houston, TX.
Looking forward to the contest.
