Yes, it does apply,
Look at the spread sheet, it covers dipoles and loops
Measure out how much wire you will be putting up.
On line 6B of the spread sheet enter the constant for a loop, 502.5
ANY numbers you see on that graph are lengths NOT TO BE USED.
You can even look on the other tabs and it shows a graphic of the wire lengths.
Any length that has a character occupying the space is NOT TO BE USED. If there is no character, that represents a good choice for wire length
So lets just say 500 feet there is an * that means do not use 500 feet or you will have difficulty on that band tuning.
Then if the next spot is let's say 508 feet where you see an *, then anything in between 501 and 507 feet will be easier to tune.
Then check if there are any warning areas for each band you plan to use.
