The LDG AT-100 Pro desktop tuner covers all frequencies from 1.8 to 54 MHz, and will automatically match your antenna in no time. It features a two-position antenna switch, allowing you to switch instantly between two antennas. The AT-100Pro requires just 1 watt to operation, but will handle up to 125 watts, making it suitable for everything from QRP up to a typical 100 watt transceiver.
The AT-100 Pro includes over 2,000 memories for each antenna, automatically storing tuning configurations for each frequency and band as you use them. Frequency sensing circuitry lets the AT-100 Pro “know” your operating band and frequency. Whenever you transmit on or near a frequency you have used before, the AT-100Pro can retune from memory almost instantly.
Rugged and easy-to-read LED bargraphs show power and SWR, and a Function key on the front panel allows you to access data like mode and status. The AT-100Pro uses latching relays which retain the tuned configuration indefinitely even when powered down; current draw when not tuning is effectively zero.
The AT-100Pro uses LDG’s state-of-the-art processor-controlled Switched-L tuning network. It will match dipoles, verticals, inverted-Vs or virtually any coax-fed antenna. With an optional LDG balun, you can also use longwires or antennas fed with ladder-line.
Control from the front panel is simple and straightforward; just press Tune while transmitting a carrier, and the AT-100Pro will begin an automatic tuning cycle.
