Who here dreams of owning this antenna
@ w9cll...
It's becoming quite evident that you have disdain for CB operators. I guess we can just imply that from now on. It'll help with any confusion.
That is still a lot of money for an antenna that will only cover legally 440khz. There are certainly smaller ones that will work just as good for a lot less and take up a lot less real estate.
$850 for 440 KHz works out to $1.93/KHz. I bought an A3WS for $500 and it covers just 200 KHz of legal spectrum. That works out to $2.50/KHz. :D
My pointing to the link was just to be informative in that there are much better options albeit not necessarily for 11 meters.
I knew someone years ago that ran the Wilson Super Laser 500, nearly the same size as the one posted here. He lived on a small lot and when it turned the antenna passed over the roof of the neighbours on both sides. He only had it up high enough so the elements would clear the roof line.
Man it must have been a super small lot. The Super Laser 500 had a boom length of 40 feet and a turning radius of about 22 feet. Unless his lot was super narrow and the neighbors houses were only 44 feet apart with his in the middle it just couldn't happen to both properties.
End of chain yanking. :)
Yank away
It was a very small lot here in the city where the homes are only four to five feel apart. Where my home is the antenna wouldn't have come near the other homes.
There's an older couple that lived in a town about 40 miles from me that had STACKED Super Laser 500's on an 80 foot Rohn tower. It was a sight to behold. Wish I'd taken a pic of it, as they have both since passed, and the nasty ice storm we had in early 2007 took down the antennas and tower. They ran a Pierce Simpson Simba modified to go to 40 channels, with a D&A 12 tube Phantom. It was a sick setup!
Could you imagine stacked Super Laser 500's on an 80 foot tower, and the kind of rotor that had to be used to TURN the damn thing? Makes my head bleed just thinking about it... :blink:
~Cheers~
maco tube is soft and extruded like a turd,
its ok for fair weather areas and folk who like fixing broken antennas,
the least i would use is dxengineering .058" wall 6063-t832 drawn tube, the stuff my i-10k is made of,
proven to my satisfaction to handle 100mph+ gusts of wind more than once,
DX Engineering Aluminum Tubing - Free Shipping on Orders Over $99 at DX Engineering
a small step up from 6063-t832 is .058" wall 6061-t6 drawn tube, the stuff my avanti's are made of, the best material ever used in cb antennas afaik,
proven to handle 110mph gusts that broke my guys and snapped the upper 43ft of mast off,
one i have yet to check out personally is the new kid on the block 6082-T6 that vortex use,
Vortex Antenna Systems – Radio Communication Antenna Manufacturer and Supplier of Antenna Hardware
Yeah. I bought some tubing off of DX Engineering to start on my X-Dipole idea before I bought the plans for a CIrcular Polarization beam antenna. . DX charges only $10 shipping.
I'm sure this 11m antenna might cover a house or two, 1SD227;
I've seen some pretty cool and crazy setups. A guy in Decatur, TX had a setoff stacked Moonraker IV's. Until the wind got them. I also knew of a set of stacked V Quads, but the owner passed away. He lived in Canada, so you know it had to be tough to survive the weather. It was quite a setup, with the "rotor" which was a motor with a chain drive in the base of the truss.
I was very happy with my 4 element yagi, and it didn't require my neighbors ducking when I turned it, and didn't cost me an arm and a leg for a rotor and tower to support it. Still (in my mind) the best bang for the buck antenna out there.
73,
RT307
There is a member here, FarmBoy that used to run a set of stack 6`s.....Signal Engineering 6 Element Quads.
What an awesome sight to behold as you drove up to his place........
Reactions: 2 people
Most of the advantage of a quad is realized in the first two elements. Notice you only see 6 element quads for 11 meters? Manufacturers with more experience will always opt for a quagi design when going beyond 2 elements. Essentially a quad antenna with yagi directors.
