'Jerk,
There is no 'one' best antenna for -all- situations. There can be and are 'best' antennas for almost any ~particular~ situation. That situation thingy means where it is mounted, fixed, mobile, whatever. With a mobile, that 'situation' is changing all the time since it's moving, or things around it are moving, traffic. That means that what may work just dandy fine at some particular place/time/environment, may not work so good at another particular place/time/environment. Unless that antenna is changing along with it's surroundings. (If you should happen to run across one'a them kind'a antennas I wish you'd get two of them, the second one for me! I'm not going to hold my breath waiting for that to happen. Not that I think you wouldn't get me one too, I just don't think you'll ever find such a beasty.)
All things considered, the biggest difference between the typical 1/4 wave whip and a 'coiled' antenna is it's rigidity. The whip is just going to lean over at speed, the other won't, at least not to the same extent. So, I figure you've got about as good as it gets for the price you paid for it. If you want to spend 5 to 10 times as much for a very -slight- increase in performance, please, be my guest. (You can have the one reserved for me! Won't bother me a bit.
When people start worrying about very slight possible improvements in what they have, I think they should take another look at the whole thing. As in, is it really worth that? The 'catch' is that while there may be some -slight- improvement, is it very practical, really, considering where it's going to be put, etc? If it's worth it to you, then do it. It's your wallet.
An antenna does not have to be resonant to perform well. It certainly doesn't hurt if it's resonant, but it isn't absolutely necessary. A 5/8 wave antenna is a very good example of that. The antenna isn't resonant all by it's self, the matching device that is used with it makes it appear to be resonant to the transmitter. Aside from one being resonant, the only difference between a 1/4 wave antenna and a 5/8 wave antenna is the shape of it's radiation pattern. That's it, just that. The 'shape' of the radiation pattern changes with length. Till you get to about 5/8 wave length, that change is typically to the better. After about 5/8 wave length, that 'shape' starts to get really sort of 'odd' looking and it typically isn't as 'good'. It's fairly easy to see if you happen to have an antenna modeling program (which also have limits and are NOT the 'cure all' of antennas). Get someone who isn't as lazy as I am to show you, it's very informative.
Shortening an antenna by adding inductive reactance, a coil, certainly works. The 'catch' is that there is always a loss of efficiency when that's done. One reason is that a coil is not very efficient to start with. The other reason is that the resulting radiation pattern will change to something 'less' than it was at 'full length'. That's one of those things that is just a fact of life, doesn't matter what anyone says, it always happens. Sometimes the benefits out weigh the loss, so it's worth doing. Other times, not. It's up to you to decide if it's worth it or not...
