Wilson 1000 wont tune on roof mount...
Something obvious will show up. I don’t know how many times I’ve had to take THAT THING apart and start over. Speaking only for myself, the problem is mainly of my own making. Skipped something, I did. Wrong whatchamacallit used. Etc.
Outside problems just add to the fun (but paint is paint, and roof metal is just roof metal).
Reactions: Handy Andy
I looked it up they look like a good idea.
Larson has a Third Brake Light Antenna Mount also, but it is for a mag-mount antenna and the coax would be exposed unless you drill a hole in the cab for the coax. I have one and I installed it on my F350 but I did not like passing the coax through a window or the door post so I removed it.
My experience with their Aluminum, is they "anodize" that metal quite a bit to make the paint stick to it.
On top of that, the "Finish metal" is a simple cap - they don't weld Aluminum (at least very well) so you may have surface area - Read: Counterpoise issues on top of the "floating lack of surface area" and the Epoxy resins used to seal the finish metal to the base frame metal keeps RF stuck to the smaller surface
So you may have "''Olde' Lang Oxide" condition making the RF issue confined.
As the OP stated, he drilled the hole and installed the
Got a brand new roof mount for the pick up aluminum of course drilled the hole mounted the mount and used the 62 in whip and the 66 inch whip still wont tune never had this problem before.. HELP!!!
As per the instructions, when I installed the third brake light antenna mount, I drilled two holes through the cab so as to attach the metal reinforcement plate inside the cab to the mount outside the cab with stainless machine screws. Being that the machine screws are making contact with the drilled holes, the metal reinforcement plate and the aluminum mount, could that explain why the VSWR on my installation is lower than what you have? If there is a non-conductive insulator in the hole in the roof, where is the metal-to-metal connection for a ground?
Reactions: Slowmover
I would like to see a picture of that 3rd brake light mount. I had the cowl mount all installed on my aluminum ford but there is no easy way to run the coax. everything is sealed.
Where there is a will there is a way. The six wires for the six upfitter switches are zip-tied in a bundle located in the engine bay, driver's side in area of brake master cylinder. I am utilizing switch one for the radar detector and switch two fore the CB radio. I drilled a 3/8" hole through the firewall and routed two 10 gage wires (with a rubber grommet) for the detector and CB. You can do the same the RG-58 CB antenna coax, except. Cut the coax, pass it through the firewall and splice the coax together with a; Shakespeare PL-258-CP-G Centerpin PL-258-CP-G
Connector. I used the same splice connector when I routed the coax from the stake pocket and through the cab into the rear seat area on the driver's side.
Bites into inside of roof:
Yes, I had one of those type connections way back on a (I think a K-40 roof mounted antenna) and I installed it on my new '86 pick-up. Those tiny ground connection points did not dig into the metal too well. So....., using the; "improvise, adapt and overcome" approach, I wire brushed the contact area of the roof to bare metal and placed a very thin flat body washer between the contact "points" on the cable assembly and the roof.
Life was good after that! That was the first and last vehicle I drilled a hole in the roof to install an antenna.
With your situation, there may not be enough space between the roof and the "prongs" to insert the thin flat washer and still have enough threads for the antenna to fully engage onto the SO239 connector.
I helped a friend install a roof mount CB antenna and after he wire-brushed the surface, we did not install a thin washer. We straightened-out the prongs so as the entire coax plate made contact with the bare metal. The prongs are suppose to dig into the paint and metal but they also stop (not too well) the coax plate from rotating when installing and removing the antenna. During the installation process, having a person inside to grasp onto the coax plate is a must! If you need to remove (unscrew) the coil from the roof for clearance, there is a very good (Murphy's Law) chance that the coax connector plate and coax will rotate at the same time and break the connection. Yeah, ask me how I know!
If you need to remove the antenna for clearance into a garage and/or onto a garage lift, I would leave the coil attached and remove the antenna mast only. It would not take too much effort for the coax connection to move and break the connection. If and when the connection does break-loose when removing the coil, the coil will also be loose and water will enter. You will have a difficult time removing the coil unless there is a person inside grasping the coax connector plate.
Just my 2 cents , and that may be what its worth . I would make up a "ground lead" temporarily using a decent gauge wire and run it from the mounting nut ground ring to a sheet metal screw inside the 3rd brake light ! It worked on a Chrysler 300 with an aluminum trunk lid and a lip mounted K-40 . Oly difference being I ran two 10 gauge wires from the mount to the spring retainer brackets for the trunk lift springs . A sheet metal screw will get enough of a bite in the "real aluminum' to make sure that is your problem . Then you can move to a more permanent solution like grinding the surface or trying to hide some ground wires !
Let us know the scoop buddy !!
73's Brian
Actually, I see several problems with this in direct install experience...
Ok, the "seams" used to anchor, seal - fix the finish metal to the cab framework is not the best for RF.
@Recon - you covered your bases when you went the thru both the support brace and finish mount together - you kept the RF ground run and the electrical DC shield run pretty much congruous READ=EQUAL to each other so you kept the SWR and DC grounding conditions satisfied..
In fact, when it (vehicle) uses either standard sheet metal (treated) or the Aluminum - both will "perforate" under Tig and Mig welds simple due to the lack of real metal they offer - so you may be able to spot weld something in these newer exotic designs for a weld - but you're also going to find several problems related to the effort it will take to fix the repair if it tears or bead/molts (or Melts) away. (Kinda like a Plasma cutter torch) The conduction is stopped in many cases simply due to the nature of the Epoxy used to bond the finish metal to the seam crimps - they realize Galvanic and Electrolytic corrosion points are the very spot welds themselves. So they used an Epoxy glue instead...
I saw many vehicles come in our shop with some type of issue with operation of either the CB, Radio or amp or combo of all - and they used a bolt that they thought went to thru to the Frame.
Well in a way, it did work, as in at one time it provided the ELECTRICAL connection as well as the PHYSICAL - but they way these frames are seamed together - you start with a base, but only spot weld to hold brackets and cage parts until other pieces of the frame and finish metals are assembled.
Assembled is a term I used here because it means just that. It's (The vehicle body) is held together by the sum of all of it's parts. One part begins to fail may not be detrimental to the performance of the vehicle. However, It has the potential to be the problem you have when it comes down to finding out why a Seat-Belt bracket Bolt can't be ground. Wait until you see where the Bonding for Battery Ground is made, not to the undercarriage, but to the main chassis that holds the engine and drive train, (like those AWD or FWD "drop ins"). It then gets bolted to the vehicle thru a process of convoluted twisting and turning to "interlock" the "fingers" the engine chassis has to the "holes" the carriage has - fit the bolts in and tighten - you're done.
That means nothing to the electrical side of the problem. But, the Seat belt bolt is held onto the undercarriage and the undercarriage is pulled along by the drive train that bolted to the engine and it's motor mounts. Ok, so we got that, but remember the undercarriage is an assembly of all those spot welded and glued together parts like front pieces, side panels, center brace and rear panels and trunk. It's all spot welded and epoxy seamed together - and that key word here is spot welded. The Epoxy is strong enough to bear the loads and maintain integrity for a considerable number of years even exposed to the elements - and when painted over - can remain sealed until "Jarred" or otherwise deformed by collision. It's the Spot weld within this panel - when it fails - that will open the circuit you're trying to complete with any type of bolt or fastener used in that particular panel.
The vehicle - in it's lifetime - can lose spot weld points and remain intact because of the integrity of the design and the epoxy welding of the pieces - but that won't make very conductive Ground Points any more effective unless you're willing to chance the idea of bolting sections together by those seams. You obtain a bond point for ground, but you may lose the ability to keep corrosion from acerbating the degradation of the joint and lessening the integrity and shortening the life of the vehicle thru corrosion once you're bolting thru.
To put this point blank, the vehicle won't rust thru if the spot weld "pops" - but anything in that region of the panels' ground points bolted to that metal may not find ground shielding like the other panels. It's a proven problem in new cars, you can see this poor ground return issue in them. They will run ok, and seem to be alright but they behave differently. They have "odd" quirks and intermittent operation of sub-sections. Its' simply due to the fact that the ground used for that sub system and the ground point it expects to have for battery power return - is not there. The Spot weld and bolt aren't making contact to the vehicles ground buss anymore.
It is no longer a simple put the bolt thru and smash the lug, Star washer - nut 2 bolt and put panels together anymore - in fact there is a specific routing of wiring and the ground buss many newer vehicles uses as a method of shielding and taming common current and low-noise routings (CAN buss systems) in a honeycomb of various folds and seams designed to provide shielding from noises as well as protection from EMF/EMP problems of todays electronics to keep these sub systems from false triggering.
You don't want your Takatah-made Airbags to go off the first time you call "Break 19" - it may be your last time you're ever heard from...
