It certainly can make a difference, but only because of misconceptions.
Hmmm, on the subject of misconceptions.
An antenna has to have certain characteristics for it to work well. It should be resonant,
5/8 lambda antennas work reasonably well, but they ain't resonant.resonant and tuned/matched are very different.
For instance, 18 feet of coax (of any kind) has no electrical characteristics that are beneficial at 27 Mhz. The only reason that length is used is because it's a nice 'average' for reaching from the radio to the antenna in most mobile installations. It does not take velocity factor into consideration (Yeah, I know, that 'dirty' word, velocity factor.
Wrong, 18 feet on any coax with a velocity factor of .66, ie the cable supplied with many magmounts, suffice to say that 18 ft is a 3/4 wave impedance inverter. i'll let you figure out the rest and why if you don't replace it with the exact length of cable it came with or an odd multiple of a 1/4 wave (which is electrically equivalent) you will find it very hard to tune.
the k40 is another antenna that uses the very same setup.
if you replace the coax with a type with a different velocity factor you have to compensate for that velocity factor and still keep it an odd multiple of a 1/4 wave.
either way that so called "NON BENEFICIAL @27 MHZ" coax length "IS" part of the matching system.
by the very same token any antenna/mount for cb that comes with 12 feet/3.6m of coax (an impedance repeater should be replaced with a multiple of a halfwave (velocity factor being accounted for), for exactly the opposite reason that an antenna using 18 feet uses its length, ITS NOT PART OF THE MATCHING SYSTEM, therefore you want it to repeat the impedance it sees at the antenna end,not transform it like the 18 foot section does.
THIS LACK OF UNDERSTANDING OF HOW TRANSMISSION LINES CAN BE USED TO TRANSFORM IMPEDANCE IS EXACTLY THE REASON THERE IS SO MUCH CB BULLSHIT / MYTHOLOGY / MISUNDERSTANDING / MISCONCEPTION, call it what you like , of why some cb antennas use 12 feet (or any multiple thereof) and some use 18 feet (or any odd 6ft multiple), there IS a reason for those lengths.
you being an amateur should know things like this DOC, especially if you intend giving out advice on antennas to cb'ers who trust you simply because you hold an amateur callsign.
