Wouxun KG-UVD1P Software Mod
KG-UV3D unlock software
Everyone talks about the unlocking software for the KG-UV3D radio but there are no links to it. I have spent hours searching for it to unlock mine after finding out they are not what they advertise. WHERE ARE THE LINKS? Can someone post one please? I also was told to GOOGLE it but it is not there.
Thanks
ben
Bumping this up :eek:)
I've attached an updated version of the 1KG-xxx-unlock.exe file. It does the same thing as the one previously posted by Moleculo but this one has been translated to English:
73, aa9az
Just bumping this up to help others
Hi,
I don't get to transmit (Wouxun KG-UVD1P)
245-250 (RX / TX )
216-280 (RX / TX )
225-226 (RX / TX )
Does anybody know it what have to do haul of configuring with the Software?
Thank you very much,
I downloaded both versions of the unlock software and renamed the file extension but I still can't get Window's to recognize the file.
Any idea's as to what I could be doing wrong?
Thanks
Dave N8DHW
Hi, i'm nw on this forum, and i've got also KG-UVD1P, both unlock software's don't work for me, those softwares says Fail to connect. Any ideas, i have serial port model of cable just bought it. And just one com-port on my desktop pc. I'm trying to extend 400-450 UHF.
Wouxun own software works, but not unlock software :(
And i think the radio is this version 144-146&430-440 MHz (RX/TX)
It's just not connecting to the correct serial port. Take a look at the first post in this thread and it describes a procedure that may work to get the unlock to choose the correct port.
Ok, problem solved, my qso room's pc com port suddenly dead, i just try it @ my laptop and it works, so sorry bothering.
Opening the Mod File
Would someone be kind enough to post how they opened the EX_ file in the WOUXUN mod? I can probably get it to work on the radio but can't open the file without buying some stupid software program called File Cure, a rip-off if there ever was a rip-off. Thanks Ron
Did anyone ever provide an answer? I have the same problem. Can't open the EX_ software to unlock the radio.
    Greg T has left the room.
