I have just acquired 2 FT-101’s I am in the process of going through them to return them to service.
In the original 101 early way under SN 25.000 there are 4 fixed channel crystal sockets on the top of the VFO inside the top cover, only 2 are wired.
In the late model 101E there are only 2 on the speech processor board same location under the top cover.
In the external VFO there are 4 fixed crystal sockets
the front switch has spots to select VFO and each of the sockets.
Is there any documentation on radio settings to use them?
How to determine the required crystal value needed for the channel you want?
Thank you for any help you can provide!
