Yaesu FT-890 AT, what do I need to control this unit via computer?
auto tuner is a waste anyway, took me a while to learn that fact
I use the AT to touch up the input to an amplifier if needed, especially 80 meters being such broad bandwidth.
AT have their uses but as stated are limited.
A good external tuner is much better for mismatches at the feedline to the antenna.
yeah that is one use I guess
  • @ Geoexplorer69:
  • @ Geoexplorer69:
