yaesu ft-901 dm
No! Actually it's Danica Patrick the Nascar Driver...
Yes I still have my FT-950 and still enjoy using it...Fine Fine receiver and sounds great on the air!
I don't see that rig going anywhere unless it was to be replaced by another FT-3000D or a FT-5000MP :)
All the Best
Gary
The 901 was Yaesu's top of the line rig in its day. I run one into a transverter and it's my 2/6 meter all mode. The only negative I can give is it does not have the WARC bands.
  • @ Geoexplorer69:
  • @ Geoexplorer69:
