Yaesu MD-100A8X Desktop Mic , and the Yaesu FT-757GX II
Raccoon
Well-Known Member
Oct 27, 2005
241
122
53
56
www.youtube.com
I have a Yaesu MD-100A8X Desktop Mic , I'd like to use it on my Yaesu FT-757GX II ? I bought a cord on ebay that was suppose to be able to match the mic to the radio , there's keyup but no audio . Has anyone else ever put an MD-100A8X on a FT-757GX II , how difficult would it be for me to get them to match up and work right together ?
You will need to supply power to the MD-100 externally.
I understand that , but doesn't the radio have a pin in it that should be already supplying power to the MD-100 , like they do with the stock mics ... and shouldn't the cord I bought already be wired properly between the radio and the mic so that they match up and work together ?
I believe you can open it up and apply +5v to pin 2 for those mics.
Reactions: Raccoon
No. The older Yaesu HF radios used a dynamic mic, that does not require power. The MD-100 has a preamp/EQ that requires 5 VDC on pin 2, that is not provided by that radio.
Ok , well I have a D104 Silver Eagle , and a Turner 254 that I can use with it . The Silver Eagle is already wired up to it , but I was wondering which one would be a better match up for the 757GX II .
I've owned many GX and GXIIs. I have found that the Turner +3 is the absolute best sounding mic of any on that radio. Keeping the gain down, of course. Never ran the mic over 9:00 position and get a sound check using the mic gain on the radio. That combo is excellent!
Reactions: Raccoon
Thanks Greg , I'll look into getting a Turner Plus 3 to go with it in the near future . So do you think that the Turner 254 would make a good match up for in the mean time , or stick with the Silver Eagle for now ?
Yaesu did a write up in the 90's, when the MD-100 came out, that would offer owners of radios that did not have 5V on pin 2. It was a dirty work around, but it works. I have not seen that write up in decades, but it was geared towards owners of FT-890, 990, 1000 etc. I modified my 990, to supply 5V on pin 2. You could easily bring pin 2 out of the mic plug to a 5V supply.
I ran that mic on my RCI 2950 years ago.
I got 12 volt positive and negative off the main board ran out the PA jack with small wires. Hooked up a 7805 voltage regulator in line for +5V. Made custom mic cord wired for all functions , even the channel/frequency up/down switch worked.
Sold it and radio when I moved up to Kenwood TS-570S. Was a neat trick tho!
Reactions: Raccoon
I'm not familiar with the 254. Can't help ya on that one.
    GlocknSpiel has left the room.
  • @ kingmudduck:
    So I have a cobra 138xlr and the meter dose not work... It dose not key up and signal dose not work.... It is not stuck it the meter moves freely. now wires are resoldered on both ends...So now that do I look at. Could it be a diode or a transistor?
    Greg T has joined the room.
    Greg T has left the room.
